查看: 1504|回复: 9
机器狗35A电调 大神说说,有什么特别的?
发表于 2018-1-18 15:53 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Robotdog机器狗 穿越机电调35A 支持2-4S BLHeli_32 32Bit大神说说,有什么特别的?
Robotdog 35A is a new 32bit BLHELI ESC that uses the latest BLheli_32 firmware. Dshot up to at least Dshot1200, and at rates up to at least 32kHz is now supported. If you are seeking for a small, powerful blheli_32 capable 32bit ESCs, the Robotdog ESCs certainly fit the bill providing 35Amps of power.
BLHeli_32 is the third generation BLHeli code, following base BLHeli and BLHeli_S. It runs on an ARM 32bit MCU, initially it will be on a Cortex-M0 running at 48MHz, but there are MCUs out there that can run a lot faster.  BLheli_32 can run input signals with lower latency at faster rates. Dshot up to at least Dshot1200, and at rates up to at least 32kHz is now supported.
Here is what BLHELI_32 has to say about their new "Power to perform":
Programmable PWM frequency of up to 48KHz
Auto-timing for higher efficiency and reliability
Voltage/Current limiting
Adjustable “Brake on Stop” force
Improve direction change in Bidirectional mode
ESC Telemetry
Configuring from FC using DShot commands
Features:
Blheli32 code
ARM 32bit Cortex-M0 MCU
1500uF cap onboard
2-4s LiPo input.
35A designed
15*25mm
Some Tips:
BLHeli_32 ESC Firmware Overview
How to Connect BLHeli_32 ESC to Congigurator BLHelisuite32 via FC Passthrough
What is Dshot1200 and Why Dshot1200 is Better?
How to Get Dshot1200 Running in Betaflight?
Downloads:
Download the latest BLHeli_32 Configurator here.
Download the BLHeli_32 User Manual here.
Download Betaflight 3.2.0 here.
发表于 2018-1-18 16:03 | 只看该作者
都 BLHeli_32了,还没ESC数传输出?
38元的30A Dshot1200 Blheli_32电调用着很好,暂时用不到35A。
发表于 2018-1-18 16:04 | 只看该作者
都1200了。
 楼主| 发表于 2018-1-18 16:15 | 只看该作者
30A Dshot1200 Blheli_32我只搜索到UFO  但也没写支持ESC数传输出
发表于 2018-1-18 16:34 | 只看该作者
这拼板方式生产的时候不怕把电容掰坏吗?
发表于 2018-1-18 16:44 | 只看该作者
Blheli32官网有介绍,数传功能正在使用中。
图片中标T的口就是数传输出口。
发表于 2018-1-18 16:45 | 只看该作者
发表于 2018-1-18 16:50 | 只看该作者
机器狗这货售价说是9.99刀
 楼主| 发表于 2018-1-18 17:15 | 只看该作者
数不清 发表于 2018-1-18 16:50
机器狗这货售价说是9.99刀
看到了, 你推荐的这个是要12.99刀,  小纠结下~
发表于 2018-1-18 17:18 | 只看该作者
人刀¥38而已。
