查看: 3914|回复: 58
不看不知道, 华XX丢脸都丢到国外去了。 气死人了!!!
发表于 2007-6-6 13:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
国内丢脸也就算了, 今天在RCGROUPS上找到本关于新手入门的电子版书,心血来潮下午开始把这本东东翻译成中文,没想到里面指名道姓说 中国的 walkera的东西不能用。 作者一口一个chinese clone ,反正都是说质量不好,而且几乎每个例子都是用的华xx的东西, 后面还直接给出了rcgroups上使用者关于质量问题讨论的链接。基本上都是说华的电子设备距离短, 抗干扰性差或者根本不抗干扰,遥控设备兼容性基本没有。rcgroups如此大的英文遥控模型论坛提供的入门教程,流传之广是可想而知的, 偏偏里面这么写国产遥控模型,看着我都跟着脸红。 其实国内好东西有的是,偏偏为了这么个垃圾牌子毁了所有人的声誉。华科尔到底是怎么想的? 除了挣钱就不能长点志气,提高一下电子设备质量??!
这里是原文:
3.2.1. Design problems
Some Chinese clones are direct or nearly-direct clones of other helicopters, but with a few changes (probably to avoid patent issues).
Sometimes these small changes cause serious problems, such as the Eflight Blade CP/Esky Honey Bee CP problems with abrupt bouncing problems in flight. Search the RCgroups Micro Helis forum for "sticky collective" or "yoyo" for more information.
3.2.2. Cheap plastic used for critical parts
The Chinese clones typically use cheap plastic for the main rotor hub, main blade grips, frames and other critical parts. The better helicopters use glass-reinforced plastic (GRP) for these parts which minimizes crash damage.
3.2.3. Low quality electronics
Many of the Chinese clones have problems with:
3.2.3.1. Transmitters and receivers
Transmitters and receivers which have limited range and/or severe interference problems (Walkera helicopters)
3.2.3.2. Servos
Servos which jitter or have poor centering, or fail after the first few flights (Walkera helicopters)
3.2.3.3. Low quality transmitter joysticks
The potentiometers in many low quality transmitters are not accurate and will cause the heli to jump around.
3.2.4. Nonstandard electronics
The Walkera transmitters and receivers are not compatible with standard negative and positive shift equipment from other manufacturer such as JR, Futaba, Hitec, Airtronics, etc.
3.2.5. Sloppy tolerances on molded and/or CNC milled parts
People have complained about Quick Heli kits (not to be confused with Quick Japan or Quick UK) having manufacturing problems.
Also seen on Walkera helicopters:
[ 本帖最后由 jpno1 于 2007-6-6 17:24 编辑 ]
发表于 2007-6-6 13:25 | 只看该作者
:em04: :em17:
发表于 2007-6-6 13:26 | 只看该作者
我的1001还行:em24:
发表于 2007-6-6 13:32 | 只看该作者
看懂一点点点点!我有华22D什么的!!!哎!!!!!
:em04:
发表于 2007-6-6 13:40 | 只看该作者
华XX,真是不争气
发表于 2007-6-6 13:46 | 只看该作者
:em16: :em17: 趁早倒闭算了。。。:em15:
唉..........:em17:
发表于 2007-6-6 14:08 | 只看该作者
:em22: :em22: :em17: :em17:
:em16: :em16:
:em16: :em17:
ESKY HONNEY BEE也拎出来批了
发表于 2007-6-6 14:18 | 只看该作者
:em17:
发表于 2007-6-6 14:19 | 只看该作者
:em04:
发表于 2007-6-6 14:30 | 只看该作者
早就知道了。。 :em18:
发表于 2007-6-6 14:37 | 只看该作者
:em16: :em16: :em16:
发表于 2007-6-6 14:43 | 只看该作者
:em17:  难过 很难过
发表于 2007-6-6 14:45 | 只看该作者
倒闭了算了~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
他的东西就不能跟别个的通用 不晓得脑壳头装的啥子
发表于 2007-6-6 14:56 | 只看该作者
:em17: 能跑到外面,還要出名,是一件不容易的事。
发表于 2007-6-6 14:57 | 只看该作者
他的东西就不能跟别个的通用 不晓得脑壳头装的啥子:em26:
发表于 2007-6-6 15:01 | 只看该作者
:em26:
