查看: 2128|回复: 8
JR9X与JR9X2的软硬件对比----软件对比
发表于 2007-12-31 21:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发表于 2007-12-31 22:13 | 只看该作者
很详细啊:em26:
发表于 2008-1-1 19:05 | 只看该作者
飞直机好象9X也够用了, 9X2到底多哪些功能,高手用语言说下! :em15:
我现在就发现9X比9X2好象要做得好一些!
发表于 2008-4-18 21:47 | 只看该作者
工程模式
我的9x2也是一樣。 听說,这是日本国內销售版本,不能调整mode1或2。
但开机时若同时按某些键,则画面会出现工程模式,即可选回国际版。
问题是,我不知道应按那些键。请高手指点。谢谢。
发表于 2008-4-18 21:56 | 只看该作者
请参考这裡
请参考这裡
http://www.helifreak.com/archive/index.php/t-2752-p-2.html
"i get into the system menu but inside the menu don't have the STICK MOD or STICK DIR.......is that my radio only can use with MODE 1??
Is locked in Mode 1 for Japan local/region of the JR 9XII. The same radio for all other regions are not lock."
发表于 2008-4-18 22:00 | 只看该作者
还有这裡 http://www.helifreak.com/archive/index.php/t-2752-p-3.html
问 "I bought the JR 9XII (same with JR 9303) last few months but I found that my radio only came with mode 1.According to the manual,we can change the radio to mode 1 or mode 2 but i can't found the "STICK MOD" & "STICK DIR" in my system menu.
Can anybody tell me how to change it?Some of the senior flyer using the same radio told me i have to open the radio & modifield some of the hardware or component inside the radio then the "STICK MOD" & "STICK DIR" will appear in the system menu.Which component I have to set the "jumper"?Can somebody show me how to do that?"
There are two different versions of the radio, one "es" version that have all fuctions enabled and one "hs" version that are locked to mode #1 and have shorter trottelstick travel, no stickdir & stick mode in the menu, no zpcm choise in the modulation menu and no alarm when turning on the radio with trottel hold or idle up turned on.
答  The stickmode selection is only locked in the software so any jr service place probably could turn it on. the other things can be turned on just by put som jumpers on the main board. check this picture:
BUT.. its on your own risk if you try and do something wrong and damage the radio.
发表于 2008-4-20 11:29 | 只看该作者
看不懂
发表于 2008-4-20 22:27 | 只看该作者
完全看不懂
发表于 2008-4-21 21:03 | 只看该作者
根本看不懂
