原帖由 HKM 于 2008-6-16 10:39 发表 ![](http://bbs.5imx.com/bbs/images/common/back.gif)
還有没有排氣管的配套能增速的那一種.
Parameter:
Type : Marine 2 cycle piston valve type gasoline engine
Displacement (cc) : 26cc
Bore x Stroke (mm): 34mm*28mm
Dry Weight (g) : 1480g
Carburetor : Walbro(Diaphragm butterfly valve type)
Maximum Output : 3.3ps /11500rmp(with resonatron)
RPM rang : 3300-18000rpm
Fuel:Gas/Oil mix 25-50:1
Lubrication Oil : 2 cycle engine oil
Cooling System : Water Cooled |
