查看: 1286|回复: 0
[转帖]The Blender
发表于 2003-2-10 06:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
What it is:
The Blender, or Panic maneuver is a vertical diving roll that virtually stops its descent as it instantaneously enters into a flat spin.
CAP set-up:
3D set-up as described in the manual. Most likely you'll have 60-75% expo with these settings. The CG should be on the mark or aft 1/2". Make sure your wing is strong-this can be an extremely violent, but always exciting maneuver.
How to do it:
Start from about 400-500 feet straight and level, chop throttle and push the nose straight down. As soon as the plane is diving straight down at low throttle, add full left aileron. Let it complete 2 or 3 rolls, then quickly transition the sticks to an inverted snap roll position (left aileron, right rudder, down elevator) all at the same time. If you do it right, the airplane will instantly transition from a left roll to a flat spin in the same direction, and the descent will all but stop. Add full throttle just after the spin goes flat making the rotation speed high and helping stop the vertical descent.
Recovery:
Simply release rudder and aileron, and hold just a little down elevator. The plane will stop rotating and begin to fly out. As it gains airspeed, roll back to upright. Remember you're in "3D mode," so don't do anything abrupt or you can stall the airplane.
http://f3a.tia.idv.tw/phpbb2/index.php
