這張圖本來就有A4格式的....只是不知道樓主從那兒找到這張全圖版本的,而竟然沒有A4格式版本.....= =..
規格原文:
Wing area: 290 sq in
Span: 30.0”
Length: 36.3”
Weight RTF: 22 to 28 oz
Wing loading: 11 to 14 oz/sq ft
Motor: Two Littlescreamers Park Jet (LSPJ)
Battery: Thunder Power 2100 mAh 11.1V Prolite
Prop: APC 6x4 regular and pusher (counter-rotating props)
Current: 36 amps total
Watts: 350 watts total
Power loading: 220 watts/lb
Speed control: Two Castle Creations Thunderbird 18 or Phoenix 25 ESCs
Receiver: Berg 7P
Flight controls: Stabilators (tailerons), rudder (optional), thrust vectoring (optional)
This model was designed specifically for twin LSPJ motors so it’s sized slightly larger than my other standard park jets, with 290 sq in wing area instead of 250 sq in. This was done to account for the higher weight of the propulsion system (two motors, two ESCs, larger battery) and thrust vectoring system, yet still provide parkflyer-type wing loading. Other motors could work OK (such as Axi 2212/20's), but they need to be lightweight (both for balance and to reduce the load on the TV servos) and spin a small diameter prop (to reduce gyroscopic effects when using the TV). However, it will be very difficult to beat the performance of the LSPJs—they are ideally suited for this application since they are so light and provide so much power with just 6" diameter props!
I haven't shot any flight videos yet since the model is still unpainted, but look for one in the near future. My next priority is to paint this ship. I'm planning to go with the stock tan/brown/white Su-37 paint scheme shown below, partly because I've got too many "air superiority grey" park jets already and partly because this will allow me to leave the bottom half of the plane unpainted (saves weight and time).
Plans for this ship are posted in a following post below.
其他設定大小分別有: (以翼展計算)
28吋
26吋
22吋
175CM
分別可選用紙張尺吋為A4 ,A0 ,或直接輸出到KT板
視頻
http://www.youtube.com/watch?v=QLR00H92SnU&feature=player_embedded
[ 本帖最后由 天迪 于 2009-9-20 16:27 编辑 ] |
