这样磨合的确有问题
OS的说明书中关于磨合就几句话,意思是只要装在模型上稍微富油飞几次就可以了,一般1.5圏就够了。
All internal-combustion engines benefit, to some
degree, from extra care when they are run for the first
few times known as running-in or breaking-in.
This is allows the working parts to mate together
under load at operating temperature.
However, because O.S. engines are made with the
aid of the finest modern precision machinely and from
the best and most suitable materrials, only a very
short and simple running-in procedure is required and
can be carried out with the engine installed in the
modle. For the first few flights with a new engine i.e.
while the engine is being run-in set the needle-valve
for a slightly rich mixture not excessively rich as this
may result in poor throttle response and cause the
engine to stope. About 1.5 turn open from the nomal
setting will usually suffice. |
