Align T-Rex 700E 3G Flybarless Helicopter Super Combo Kit w/Motor, 4 Servos (CF Blades)
[AGNKX018E01] | Low Price: $1,299.99 |
This item earns up to 1300
Customer Rewards Points!
In Stock!
[url=]Wish List!Wish List![/url] | [url=]Buy Now!Buy Now![/url] |
| This is the T-Rex 700E super combo kit from Align with the 3G Flybarless Electronic Stabilization system. Once again Align overthrows traditional RC helicopter designs with this electric version of the T-Rex 700. Electric power transcends the capabilities of Nitro engines to take large heli performance to new levels! The 700MX 510Kv motor and Castle Creations HV 120A speed controller offer even more torque and power to push the T-Rex 700E performance beyond amazing! With the increased performance and stability and agility of the 3G flybarless system the performance becomes astounding! Electric flight is also quieter and cleaner so there is no oily mess to cleanup at the end of your flying day! Sliding battery tray rails and a innovative battery retaining system are but two of the features that make this amazing 90 class heli stand out.
Features
- 700MX 510Kv motor and Castle Creations HV 120A ESC
- All metal main blade control system, resulting in enhanced durability and control precision.
- New lateral adjustable metal left right control bell crank arms and elevator control arms, enabling the most ideal endpoint travel adjustment for 3G flybarless as well as flybar system, while increasing servo resolution for improved control precision.
- Innovative sliding battery tray rails imbedded into the 3K side frames, allowing for quick battery access as well as battery protection.
- Top mounted motor base bringing the motor's center of gravity closer to rotating disc, improving 3D agility and allowing blade drafts to cool the motor effectively.
- Utilizes mod 1 gear pitch for improved power sustainability of main gear.
- Side frame attached third motor bearing block to ensure trueness of motor shaft at extreme radial force. This enhances the motor efficiency for longer motor life and decreases the sudden changes in gear mesh.
- Top mounted ESC platform to take advantage of main blades airflow for effective cooling.
- New lightweight H-shaped electric device retention system for protection, as well as ergonomically correct design to simplify operation.
- Wide +/- 15 degree pitch range for superior 3D performance and explosive power.
- Utilizes high efficiency tail drive shaft system.
Specifications
Length: 1328mm
Height: 408mm
Main Blade Length: 690mm
Main Rotor Diameter: 1562mm
Tail Rotor Diameter: 281mm
Motor Drive Gear: 12T
Main Drive Gear: 115T
Autorotation Tall Drive Gear: 104T
Tail Drive Gear: 24T
Drive Gear Ration: 1:9.587:4.33
Weight (With Motor): 2830g
Flying Weight: Approx. 4700g
Needed To Complete
Transmitter(7-channel or more, helicopter system)
Receiver(7-channel or more)
6S Li-Po 4500 ~ 5200mAh X2
Pitch Gauge
比700E贵了不少。。:em17: !
[ 本帖最后由 465723359 于 2010-9-25 08:16 编辑 ] |
