查看: 3188|回复: 14
Spektrum DX8果然升级了~~dsmx来了
发表于 2011-2-10 11:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天收到Spektrum的升级通知,果然DX8如我上次说,迎来了版本升级,升级的内容:
AirWare v2.0 is now available for download on the community site!
Version 2.00
Software Upgrades
• DSMX is enabled.
• DSMX/DSM2 bind mode is now shown on the main screen immediately to the
right of the Spektrum logo.
• DSMX/DSM2 mode selectable on the Frame Rate screen. Note that a DSMX
receiver is necessary for DSMX operation.
• Added support for new Telemetry sensors Airspeed, Altitude, and PowerBox.
• Receiver Voltage is now shown on the Min/Max screen.
• Telemetry menu is now a scrolling list, to improve ease of use as the number of
possible sensors increases.
• When setting the Flight Pack Voltage alarms, you can easily set the alarm points
based upon LiPo cell count, then tweak them to your preference.
• The low-level SD interface is updated to improve compatibility with PC’s.
• Mix and Gear switches can now be used in mixing functions to have the active
position either 0 or 1. These are named Mix-0/Mix-1 and Gear-0/Gear-1. The “1”
option is the same as the old Mix or Gear option, as the mix function was
previously active in position 1.
• The Timer Setup screen now hides information which is not related to the
selected timer mode.
• In Elevon wing types, the Flap System is enabled, providing the flap function on
Aux 1 and enabling proper elevator compensation. In this mode, the Aux1
channel would typically be used either as a drag brake or a spoiler.
• The Serial Number screen now includes an EXPORT function to make it simpler
to enter the serial number when registering a new radio.
Software Corrections
Mix Switch – The Mix Switch was sometimes treated as a 3-position switch.
Mode-Change Recalibration – When changing between Mode 1 and Mode 2,
the throttle and elevator sticks were calibrated to different tolerances than during
factory calibration.
Telemetry Alarming – Corrected problem with multiple alarms on main voltage
sensor inter-acting with one another.
发表于 2011-2-10 11:58 | 只看该作者
沙发:em19:
 楼主| 发表于 2011-2-10 13:01 | 只看该作者
原帖由 neowu4 于 2011-2-10 12:48 发表
不知要如何升级~莫非发到厂家???那路途遥远了。。。
网站下 载,复制到SD卡,然后开机升级~~~简单
发表于 2011-2-10 13:27 | 只看该作者
dsmx:em26:
 楼主| 发表于 2011-2-10 14:15 | 只看该作者
DX8_AirWare_Version_2.0
DX8_AirWare_Version_200.pdf
69.2 KB, 下载次数: 242
发表于 2011-2-11 11:18 | 只看该作者
已经成功升级。今晚回家试试,原配的AR8000 接收是否两种模式通吃..
发表于 2011-2-11 12:26 | 只看该作者
以前的BUG不小啊,改变模型的时候油门和升降舵的精度会改变。不过厂家还是更正了
 楼主| 发表于 2011-2-11 14:00 | 只看该作者
原帖由 zjzd 于 2011-2-11 12:26 发表
可以随时更新固件,就是好啊
发表于 2011-2-11 21:47 | 只看该作者
跟spktrum走,听spektrum的话,没错
发表于 2011-2-12 00:13 | 只看该作者
XG7谁生的
发表于 2011-2-12 01:32 | 只看该作者
原帖由 mogupu 于 2011-2-11 11:18 发表
可以的,我在用了。:em24: 接线快。
发表于 2011-2-22 17:13 | 只看该作者
结果怎样?快发上来。
发表于 2011-7-12 09:07 | 只看该作者
官网找了半天没发现下 载地址,求地址 :em15:
发表于 2011-7-12 15:13 | 只看该作者
这次返回来的控都是2.02了
发表于 2011-9-12 11:09 | 只看该作者
刚刚注册好了2.03beta版都有了
