查看: 1027|回复: 4
先豪........!!!!!
发表于 2003-3-18 07:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
I found that ....the tail motor speed of 先豪 is too high
I just use the main rotor for my tail,
when I put the "rudder stick to right,
I found that the motor speed is equal to " main blade" speed!!!
which mean the current give to the tail motor is too high!!!
anyone can share this problem with some comment ?
thanks :em17:
发表于 2003-3-24 05:30 | 只看该作者
先豪........!!!!!
尾浆转速太高,混控有问题吧。
发表于 2012-10-7 23:45 | 只看该作者
发表于 2012-10-8 02:27 | 只看该作者
我靠,古墓!
发表于 2012-10-8 02:26 | 只看该作者
我靠,古墓!
