查看: 1008|回复: 6
谁认识这个充电器?
发表于 2011-12-23 10:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
谁用过这个充电器?搜索了一下,坛子里从来没有人提到过补两张图片:
[ 本帖最后由 whfweb 于 2011-12-30 11:54 编辑 ]
发表于 2011-12-23 11:06 | 只看该作者
图片挂了
 楼主| 发表于 2011-12-23 11:13 | 只看该作者
图片已重新上传
发表于 2011-12-23 13:09 | 只看该作者
应该和B6属同一类,看型号应该可以充8S
 楼主| 发表于 2011-12-23 15:30 | 只看该作者
2148 - PRO-8 Charger Balancer
Microprocessor controlled high-performance digital rapid charger/discharger for
NiCd, NiMH, Li-poly and Pb batteries. Designed to maintain your battery at its best condition
DC entry.
Charge/discharge current up to 7A.
10 data memory.
1~8 series Li-ion/poly.
1~27 cells NiCd/NiMH with adjustable Delta-peak sensitivity (mV).
6,12 and 24V lead acid (Pd) batteries.
3-8 cell balance mode.
1-5 charge/discharge cycles.
Microprocessor controlled.
Efficient cooling system with automatic cooling fan.
Temperature cut-off.
"Auto" function; every program is controlled in order to prevent every possible error so it guarantees a maximum safety.
Operating program upgrade; the operating program can easily be upgraded through the external port
Upload of data is possible via the integrated USB port. An USB cable and software are included. You can monitor all the important parameters (Volt, Amperage, cell per cell status of LiPo batteries, ...) on your pc.
Input power monitor: the input voltage is always monitored. If it drops below the lower limit the process will be ended automatically.
Capacity limit: if preset, the process will be terminated automatically.
Various cables are included in the packaging.
Technical specifications
Charge  0,1~7 A
Charge & Discharge  1~5 cycles
Cooling  Yes
Discharge  0,1~5 A
Input Power  11~18 V
LiPo cell(s)  1~8
Memory  10
Model  PRO-8
Multi Conn.  Included
NiMH & NC cells  1~27
Output Power  0,1~7 A
Pb Battery  6V-12V-24V
Temp. sensor  Yes
USB  Yes
发表于 2011-12-23 17:29 | 只看该作者
B6的兄弟
发表于 2011-12-23 19:38 | 只看该作者
看上去是个能充8S的B6
