查看: 5284|回复: 25
禅思貌似已被山寨
发表于 2012-5-2 00:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Photohigher Hero 系列
Name:
HERO Series Camera Gimbals
Description:
The Hero Series camera gimbals are innovative high quality three axes camera gimbals designed for the film industry. They are light weight high tech products using leading edge technology.
Details: Hero 2000
The Hero series camera gimbalsare 3 axes stabilised camera gimbals, constructed from 100% carbon fibre.  The carbon fibre chassis are hollow to ensure light weight and high strength.  There are three Hero gimbals which are:
  • Hero 1000 - for the go-pro
  • Hero 2000 - NEX 5, GH2
  • Hero 3000 - Epic, NEX 100, C300
  • Hero 3D - commin soon!
Each camera fitted to the Hero can be perfectly balanced with PhotoHighers innovative 2 axes camera tray allowing the user to finely adjust the Z axes (up and down) and X axes (forward and back) of the camera.  A well balanced camera increases the performance of the gimbal and ensures very accurate stabilisation.  Alowing the camera to float in the gimbal ensuring perfect rock solid gimbal stabilisation.
Hero 2000 Specifications:
Pan axes – 360 degrees continuous travel
Roll Axes – 300 degrees travel
Tilt axes – 180 degrees of travel
Total Weight (without camera) – 780g
Overall Dimensions – W 247 x H 230 x D 195mm (Width x Height x Depth)
Drive system – Zero backlash direct drive
Power – 18v
看起来跟Z15结构非常像,产品化程度更好些
DJI得赶紧了,在国外发布的过早了啊,没量产能力前,发布要谨慎
[ 本帖最后由 nodbao 于 2012-5-2 01:03 编辑 ]
发表于 2012-5-2 00:23 | 只看该作者
早看到实物图了 结构看来是比dji要结实些 实际效果如何 不知到
发表于 2012-5-2 00:29 | 只看该作者
回复 楼主 nodbao 的帖子
呵呵,有FOR gopro的了,期待视频
发表于 2012-5-2 07:02 | 只看该作者
等视频
发表于 2012-5-2 08:22 | 只看该作者
价格估计会很给力
发表于 2012-5-2 08:25 | 只看该作者
没有预定优惠,没有老客户优惠,你确定买的下手?呵呵:em15:
发表于 2012-5-2 10:20 | 只看该作者
没有独立IMU 不行的
发表于 2012-5-2 10:23 | 只看该作者
这个应该比禅寺结实  简单才是硬道理
发表于 2012-5-2 10:27 | 只看该作者
这个有独立的IMU,不过只是用垃圾芯片的而已,skyline:em15: 价格会相当坑爹
另外他们试飞的多旋翼,都是DJI飞控:em15: :em15:
 楼主| 发表于 2012-5-2 10:52 | 只看该作者
原帖由 cici9911 于 2012-5-2 10:20 发表
没有独立IMU 不行的
......无语,机械部分是关键,独立IMU可以自己配的,就像AV200那样
完全可以选用风评较好的云台增稳陀螺
可以很方便的做成云台由另一套发射机独立控制
禅思还不知道能不能呢
跟wkm捆绑的,是否接受双接收机输入,也从来没说过
[ 本帖最后由 nodbao 于 2012-5-2 10:55 编辑 ]
发表于 2012-5-2 11:00 | 只看该作者
有竟争,价格才有优惠!!:em15:
 楼主| 发表于 2012-5-2 11:00 | 只看该作者
原帖由 123_123 于 2012-5-2 08:25 发表
上这种云台的,追求的是品质,价格是不太敏感的
有多种产品可以对比选择当然是好事
当然,老外看起来挺像是抄的,该维护自己权益的时候也别手软,
话又说回来,DJI这种预定方式真优惠了吗:em22:
发表于 2012-5-2 11:02 | 只看该作者
发表于 2012-5-2 12:58 | 只看该作者
:em04:
发表于 2012-5-3 23:37 | 只看该作者
原帖由 nodbao 于 2012-5-2 11:00 发表
有多种产品可以对比选择当然是好事
话放在这里,比品质,photohigher也绝对不是DJI的对手
发表于 2012-5-4 07:40 | 只看该作者
技术市场上没有永远的霸主
 楼主| 发表于 2012-5-8 19:37 | 只看该作者
原帖由 123_123 于 2012-5-3 23:37 发表
比违约和不讲信誉,估计也没几个是DJI的对手
发表于 2012-5-10 01:15 | 只看该作者
楼上说的在理!严重同意!
发表于 2012-5-10 17:05 | 只看该作者
谁抄谁的,这个不好说吧……现在总感觉什么都是抄的:em15:
发表于 2012-5-14 05:03 | 只看该作者
:em15:
