查看: 1544|回复: 3
APM2 新固件 2.5.5
发表于 2012-5-17 10:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Arducopter 又有新固件2.5.5,每个月最小一次更新,速度之快真是无语!
http://code.google.com/p/arducopter/downloads/detail?name=ArduCopter-2.5.5.zip&can=2&q=label%3AFeatured
原文
ArduCopter 2.5.5 release.<br>A patch release which has the following improvements over 2.5.4:
1. MPU6000 accelerometer scaling fix (affected 3dr APM2s shipped from early May)
2. "Retro Loiter" by Adam Rivera (uses ground speed directly from GPS instead of calculating from lon/lat position)
3. Optical flow support for APM2
4. bug fix for "need to press reset before arming motors"
[ 本帖最后由 monkey1 于 2012-5-17 10:07 编辑 ]
发表于 2012-5-22 09:41 | 只看该作者
刚刷了四轴的,还没试呢
发表于 2012-5-22 10:36 | 只看该作者
等便宜的出来再搞。。:em15:
发表于 2012-6-3 23:48 | 只看该作者
不错
