美國IMPBA規章 2006年3月Technical Standards, Section K-5, Hull Classification:
1. Mono Hull Definitions and Restrictions
A “Mono” is a hull that has a continuous wetted surface when operating at racing speed. A Mono must incorporate the following design characteristics and not exceed any of the dimensional restrictions.
1.a. A hull that has no discontinuities between or steps in the wetted surface running at more than a 15-degree angle with keel, in plane view (bottom view).
1.e. Wings are illegal on a Mono.
翻譯成中文是:
1....單體船必須有下列特徵...
1.a....不允許有階...。
1.e.單體船不允許有翼。
美國IMPBA規章 2006年3月Technical Standards, Section K-7, Hull Classification:
2. Hydro Hull Definitions and Restrictions
In addition, any hull with added appendage, with air lifting characteristics capable of lifting
the hull free of water while maintaining stability, will also be classified as a HYDRO.
翻譯成中文是:...任何船體...有空氣助升特性....會被評定為多點式。
美國NAMBA規章Section Name: HULLS, Section Revised on 3/15/06:
C. HYDROPLANE HULL
1. If a hull does not meet the requirements to be classified as a monoplane then it is
automatically classified as a hydroplane. Examples of hydroplanes:
翻譯成中文是:如果一個船體不符合單體船的規定,便會自動被評定為多點式。
