查看: 952|回复: 18
飞行语录
发表于 2013-12-22 20:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
飞行员手册
(虽然是笑话,但有部份却是事实 ]
Every takeoff is optional. Every landing is mandatory.
每个起飞是自愿性的, 每个降落是强迫性的。
Always try to keep the number of landings you make equal the number of take offs you've made.
经常保持降落数目与起飞数目相等。
When in doubt, hold on to your altitude. No-one has ever collided with the sky.
当你觉得混乱时,请保持高度,因为没有人跟天空相撞过…
The probability of survival is inversely proportional to the angle of arrival. Largeangle of arrival, small probability of survival and vice versa.
生存的机会是跟着陆角度是成反比例的。大的着陆角度,小的生存机会…
There are three simple rules for making a smooth landing. Unfortunately no one knows what they are.
要做出好的降落有三个原则,但不幸地,没人知道是哪三个…
If you push the stick forward, the houses get bigger. If you pull the stick back, they get smaller... That is, unless you keep pulling the stick all the way back, then they get bigger again.
当你把控制杆推前,房子变大了;当你把控制杆拉后,房子变小了;但当你拉着不放,房子又要变大了。
You start with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
开始时你有两个袋,运气袋装得满满的,经验袋是空空的。关键就在于,在运气袋变空之前,请把经验袋装得满满的!
Good judgment comes from experience. Unfortunately, the experience usually comes from bad judgment.
好的判断来自经验。很不幸,经验通常是来自坏的判断……
The three most useless things to a pilot are the altitude above you, runway behind you and a tenth of a second ago.
对于飞行员来说,最没用的三件事:在你上面的高度、在你背后的跑道,以及刚过去的十分一秒。(三件事也可以理解為:白白损失的高度,失误错过的跑道,以及刚过去的十分一秒。)
There are old pilots and there are bold pilots. There are, however, no old bold pilots.
这里有老飞行员,也有勇敢的飞行员;但是,这里并没有勇敢的老飞行员。
You know you've landed with the wheels up if it takes full power to taxi to the elevator.
当你要开加力才能把飞机驶进停机坪,你就知道刚才降落时, 忘记了放下起落架
Flying isn't dangerous. Crashing is what's dangerous.
飞行不是危险的,坠毁才是危险的!
The ONLY time you have too much fuel is when you're on fire.
你唯一会嫌汽油太多的时候,就是着了火的时候…
A 'good' landing is one from which you can walk away. A 'great' landing is one after which they can use the plane again.
一次“好” 的降落,就是说你可以安全步离机舱;一次“极好” 的降落,就是说这架飞机可以再用。
The propeller is just a big fan in front of the plane used to keep the pilot cool. When it stops, you can actually watch the pilot start sweating.
螺旋浆其实只是一个令飞行员凉快的大风扇,当它停了,基本上你会看到飞行员开始冒汗了…
Helicopters can't fly; they're just so ugly the earth repels them.
直升机不能飞的,只是它们太丑了,连地球也排斥它们
发表于 2013-12-23 09:58 | 只看该作者
学习了
发表于 2013-12-23 10:01 | 只看该作者
我爱模型
发表于 2013-12-23 12:41 | 只看该作者
顶起
发表于 2013-12-23 12:54 | 只看该作者
顶一下
发表于 2013-12-23 13:27 | 只看该作者
顶个。
发表于 2013-12-23 21:18 | 只看该作者
入魔新手,学习了。
发表于 2013-12-25 23:50 | 只看该作者
额额~roger that。。。。
发表于 2013-12-26 17:22 | 只看该作者
顶起
发表于 2013-12-27 09:40 | 只看该作者
学习了,啥也没记住
发表于 2013-12-27 10:23 | 只看该作者
有意识
发表于 2013-12-29 20:44 | 只看该作者
哈哈,不错~
发表于 2014-2-10 17:43 | 只看该作者
飞行
发表于 2014-2-19 13:08 ——“来自手机” | 只看该作者
有意思
发表于 2014-2-27 15:26 | 只看该作者
有意思
发表于 2014-3-4 20:31 | 只看该作者
学习英语神器
发表于 2014-3-5 17:24 | 只看该作者
拿分走人
发表于 2014-3-11 21:27 | 只看该作者
不错的语录
发表于 2014-3-11 21:36 | 只看该作者
新人拿分 帮顶 不谢
