如图,在配置文件中开启GPS支持后在GUI里面调试,传感器各种抽风
GPS部分配置代码如下
- /*********************** GPS **************************/
- /* GPS using a SERIAL port
- if enabled, define here the Arduino Serial port number a n d the UART speed
- note: only the RX PIN is used in case of NMEA mode, the GPS is not configured by multiwii
- in NMEA mode the GPS must be configured to output GGA a n d RMC NMEA sentences (which is generally the default conf for most GPS devices)
- at least 5Hz update rate. uncomment the first line to select the GPS serial port of the arduino */
- //#define GPS_SERIAL 2 // should be 2 for flyduino v2. It's the serial port number on arduino MEGA
- //#define GPS_PROMINI_SERIAL // Will Autosense if GPS is connected when ardu boots.
- // avoid using 115200 baud because with 16MHz arduino the 115200 baudrate have more than 2% speed error (57600 have 0.8% error)
- #define GPS_BAUD 57600
- /* GPS protocol
- NMEA - Sta n dard NMEA protocol GGA, GSA a n d RMC sentences are needed
- UBLOX - U-Blox binary protocol, use the ublox config file (u-blox-config.ublox.txt) from the source tree
- MTK_BINARY16 a n d MTK_BINARY19 - MTK3329 chipset based GPS with DIYDrones binary firmware (v1.6 or v1.9)
- With UBLOX a n d MTK_BINARY you don't have to use GPS_FILTERING in multiwii code !!! */
- //#define NMEA
- #define UBLOX
- //#define MTK_BINARY16
- //#define MTK_BINARY19
- //#define INIT_MTK_GPS // initialize MTK GPS for using selected speed, 5Hz update rate a n d GGA & RMC sentence or binary settings
- /* I2C GPS device made with an independant arduino + GPS device
- including some navigation functions
- contribution from EOSBa n di http://code.google.com/p/i2c-gps-nav/
- You have to use at least I2CGpsNav code r33 */
- #define I2C_GPS
- // If your I2C GPS board has Sonar support enabled
- //#define I2C_GPS_SONAR
- /* GPS data readed from Misio-OSD - GPS module connected to OSD, a n d MultiWii read GPS data from OSD - tested a n d working OK ! */
- //#define GPS_FROM_OSD
- /* indicate a valid GPS fix with at least 5 satellites by flashing the LED - Modified by MIS - Using stable LED (YELLOW on CRIUS AIO) led work as sat number indicator
- - No GPS FIX -> LED blink at speed of incoming GPS frames
- - Fix a n d sat no. bellow 5 -> LED off
- - Fix a n d sat no. >= 5 -> LED blinks, one blink for 5 sat, two blinks for 6 sat, three for 7 ... */
- #define GPS_LED_INDICATOR
- //#define USE_MSP_WP //Enables the MSP_WP comma n d, which is used by WinGUI to display a n d log Home a n d Poshold positions
- //#define DONT_RESET_HOME_AT_ARM // HOME position is reset at every arm, uncomment it to prohibit it (you can set home position with GyroCalibration)
- /* GPS navigation can control the heading */
- #define NAV_CONTROLS_HEADING true // copter faces toward the navigation point, maghold must be enabled for it
- #define NAV_TAIL_FIRST false // true - copter comes in with tail first
- #define NAV_SET_TAKEOFF_HEADING true // true - when copter arrives to home position it rotates it's head to takeoff direction
- /* Get your magnetic declination from here : http://magnetic-declination.com/
- Convert the degree+minutes into decimal degree by ==> degree+minutes*(1/60)
- Note the sign on declination it could be negative or positive (WEST or EAST) */
- //#define MAG_DECLINATION 3.96f //For Budapest Hungary.
- #define MAG_DECLINATION 1.61f //(**)
- #define GPS_LEAD_FILTER // Adds a forward predictive filterig to compensate gps lag. Code based on Jason Short's lead filter implementation
- //#define GPS_FILTERING // add a 5 element moving average filter to GPS coordinates, helps eliminate gps noise but adds latency comment out to disable
- #define GPS_WP_RADIUS 200 // if we are within this distance to a waypoint then we consider it reached (distance is in cm)
- #define NAV_SLEW_RATE 30 // Adds a rate control to nav output, will smoothen out nav angle spikes
复制代码
请问是怎么回事啊,调了一晚上了都。没开启之前正常
