[f Hitec OPTIC 6 JR XP6102 Airtronics RD6000Super Futaba 7C
$209.99 $249.99 $249.99 $249.99
Standard Features
Channels : 6 6 6 7
Synthesized Module Option Yes: SPECTRA No No No
Model Memory : 8 10 8 10
Shift Select: Yes No Yes No
Model Name :7 Character 8 Character 3 Character 6 Character
Model Programming :ACRO/GLID and HELI ACRO and HELI ACRO and HELI ACRO and HELI
Switch Assignability: Yes Yes No No
Modulation :FM / QPCM FM / PCM FM / PCM FM / PCM
Digital Trims: Yes Yes Yes Yes
2 Position slide Switch: 3 4 4 5
3 Position Toggle Switch :1 No 1 1
AUX volume :2 Sliders 2 Rockers 2 Buttons 1 Knob
Push Button :1 2 2 No
Trainer: Yes Yes Yes Yes
Engine Cut: Yes Yes Yes Yes
Timer :3 Timers No 4 Timers 2 Timers
Trim Step: No No Yes No
DSC, Direct Servo control :No Yes No No
Low Battery Warning: Beep Beep Beep Beep
ACRO / GLID Functions
Dual Rate Yes,: Ch. 1,2,4 Yes, Ch. 1,2,4 Yes Yes, Ch 1,2,3,4
Exponential Yes :Ch. 1,2,4 Yes Ch. 1,2,4 Yes Yes, Ch 1,2,3,4
Servo Reverse: Yes Yes Yes Yes
Sub Trim :Yes Yes Yes Yes
End Point Adjust: Yes Yes Yes Yes
Ailervator :Yes No No No
Programmable Mix : 2 4 5 3
Aileron to Rudder: Mix Yes Yes No Yes
LANDING or Flap / Elev :Yes Yes No Yes
Elevon Mix: Yes Yes Yes Yes
Flaperon Mix: Yes Yes Yes Yes
V-Tail Mix :Yes Yes Yes Yes
2 Flap Wing :Mix Yes No Yes Yes
CROW / Butterfly Yes No Yes Yes
Snap Roll : No No No Yes
Aileron Differential: Yes No Yes No
HELI Functions
CCPM : 120 120, 180 4 types 5 types
90 Mechanical: Yes Yes Yes Yes
Rudder / Throttle :Yes No Yes Yes
Points in Throttle Curve: 5 5 5 5
Points in Pitch Curve :5 5 5 5
Throttle Hold :Yes Yes Yes Yes
Revo Mix :Yes Yes Yes Yes
Swash Mix :Yes Yes Yes Yes
Gyro Gain :Yes No Yes Yes
Rudder Offset: No Yes Yes Yes
Program Mixes: 2 2 1 3
Stunt Curves :2 1 2 2
ont=黑体]Sample TextSample Text:em26::em14::em06: |
